Hi:
I am looking at a 7720 combine. Overall in good condition except the motor will run at full rpm and the kill switch does not work. Is this an injection pump issue or a cable issue stuck at full throttle?
The combine has not been used for several years. I am told the unit has been started every year and all working parts engaged until 2024. It has not been on the field since around 2020. In 2024 it was driven out of storage and has been stored outside since then. The combine now will start right up with no problems but it will immediately go to full rpm and cannot be shut off without depriving it of air or fuel.
Any way I can test what the issue is with the runaway?
