JD 858 rake teeth
Ksracer
I bought a JD 858a bar type rake that has rubber mounted teeth. Are the steel spring teeth supposed to be a direct bolt on or am I missing something? I'm having trouble with them twisting on the bolt. I see tooth clips for the New Holland rakes for sale but none for the JD.
[/img:fa60ef5ea6]
Yep,there is a metal clip that holds the tooth from rotateing.They are a 1 wide by 1/8 inch strap that is bent around the pipe,with a slot in one end for the tooth,and a hole in the middle for the bolt. You
can easily make them. My rake also has a combination of rubber and steel teeth.
From what I can see, the slot in the clip is on the wrong side, but I'm going to get some and try anyway. Maybe I need to see if the NH teeth will fit, except I already bought 25 of the JD teeth.
Thanks guys. I found a JD part number g6760e but they're $30 each. I checked out the dimensions on the NH teeth and I think they will bolt right on, then I can use the NH clips that are $1 each.
Thanks for the tips guys. For anybody searching this post in the future, I ended up using a piece of .125" x 1.5" angle. I used the Bridgeport because it will be a simple matter to make 20 more identical pieces, but you could do it with a drill and a grinder if you had some patience.
(quoted from post at 05:18:36 09/16/23) This is one of those posts where you wish this site had a "LIKE" button. Hope you don't mind I'm going to steal that design.
Here are dimensions I used. Have at it!
Each one is 4.5" long. I drilled the holes 13/32 so a carriage head bolt would smash into them. If you're doing it by hand, I'd use a regular bolt so the clip could slide sideways for adjustment. The slot is 5/16 wide but the left edge is the only part that matters. As long as the left side of both slots are spaced 3.125" apart, you should be good to go.
