Okay I am officially stumped and looking for any advice. We had a reverse gear fuse onto the top assembly on an 8630. The tractor would go forward in several gears but would stall itself out in a reverse gear. We pulled the top assembly and replaced the shaft, reverse gear, clutch pack and synchronizer. After reassembly she ran beautiful for 30 minutes pulled just a 26 set of sweeps. As soon as I used a reverse gear, it locked up again. Im looking for any advise as it seems to be possibly a lube problem. Is it possible the transmission pump under rocker shaft is not supplying lube to shaft? The funnel coming from top of transmission cover seems to be dumping lube onto the assembly fine.
Any help would be greatly appreciated.
Kris
Kris
