Pete Kaufman
Anybody had any experience with 4WD tractor steering problems, my 8650 steers hard in both directions. It is not the filter and the main hydraulic pump seems to be ok because it raises and lowers the ripper ok. Any help would be appreciated. Thanks
The spool may be sticking in the steering valve under the hood in front of the dash. remove the big plugs on each end and see if the spool moves smoothly.
I have had to rebuild the steering cylinders on my IH 4366. The piston seal lets the oil bypass making the other cylinder do the work of two.
An inexpensive place to start.
Good Luck.
Dave
