The guy I farm with tested a 9530? and Quad and Cat. He ended up with a 865 Cat. The seals on the pivot on the rear drivers leak. Other than that okay. The Deere rode rough and road travel was sporadic. The Quad has this LITTLE gear shift with SMALL buttons for shifting and hydraulics. A friend has all Deere except two Versatile tracks. The quality of the Deere and electronics was junk. One time they got in a corner and couldn't get it to shift because the cab air or ac switch went bad. He sat there 3 hours and his cousin was the dealer.
The rear ends are a little weak in them. There is a replacement cover for the rear end that solves the biggest problem. Might want to check to see if it has been updated. If you don?t catch it in time and it fails it is $10,000 plus. I had one strip the splines out of the diff carrier too, not sure if that was a fluke or potential weak point.
