JD A CARB BRASS
if you take the big nut off the bottom of the JD A carb... a spring and a brass tube should fall out. the tube is about 1/4 inch in diameter, has a bunch of little holes around it and sticks up into the throat of the carb. does anyone know where i might find this brass part? thanks for the help
(quoted from post at 22:23:43 11/29/12) if you take the big nut off the bottom of the JD A carb... a spring and a brass tube should fall out. the tube is about 1/4 inch in diameter, has a bunch of little holes around it and sticks up into the throat of the carb. does anyone know where i might find this brass part? thanks for the help
The part is called a nozzle. Others may have them, but Roberts Carb lists them for sale.
http://www.robertscarbrepair.com/carbid.asp
