We are working on a 47 JD A. We have sleeved block, done Valve job etc. Upon reassemble yesterday, I noticed that while turning the engine over the exhaust port is blowing like it should but it is also sucking air. We have not messed with the timing on the tractor (Did not remove crank or cam) Only new pistons, cylinders, valve seats, etc. I have set valve lash to fix intake slight blowing (not as bad as exhaust) I cannot fix exhaust side the by adjusting lash. The only thing I did notice is that the 2 push rods on the Left are spinning some of the time while the right 2 do not. We purchased this tractor running with only about 30psi/cylinder. This was an all fuel which I have no experience with. Maybe the its supposed to suck and blow from the exhaust. Help if you can. Why is this happening? How do I fix?
