JD A Hub/Clamp ???
Meangreen
So here is the situation I face. As you can see in the picture my hubs and clamps are in as tight as they can go. The manual says to use a punch to loosen the hubs. Any of you guys have any other tricks?
You are trying to remove the centers? Unbolt the centers from the hub. Then you can pop the clamp off. Once that is done you can slide the hub off.
Unboly the HUB from the CAST WHEEL, make it as easy as possible and te work on getting the CLAMP loose. Yes a BRASS or STEEL DRIFT will work , it has BEFORE. Good luck. PS: As for what little you may ruin, the parts are all over. Next time use some WAX PAPER as has been used for YEARS.
Unbolt the HUB from the CAST WHEEL, make it as easy as possible and then work on getting the CLAMP loose. Yes a BRASS or STEEL DRIFT will work , it has BEFORE. Good luck. PS: As for what little you may ruin, the parts are all over. Next time use some WAX PAPER as has been used for YEARS.
I purchased the tractor this way, no waxed paper. I have encoutered this many a time, but this is the first time I have encoutered a hub this far in on a tractor in this position.
Quoting from my operators manual, "when the hubs are moved in for narrow clearance, the only way to remove the clamps is to use a punch and a BFH and hit "em from the outside".
