jd a idle problem
alvan
I have a 1945 jd a carbrator has been compleatly rebuilt when it idles or runs at mid to low speed it paul saits. You put the chocke on haft it smooth out any sujestions Thanks
If backing out the idle adjustment (on Left side of carb) doesnt fix the pulsating then for sure the passages are not clean. Send it back to whoever worked on it.
you donot need to send it out, just do it yourself. roberts carb has picturs of the idle passage that you need to clean out on the website. you can also get the long drill bit you need from them (or get a long aircraft bit localy) if you invest in the bits you will find it easy to repair the simple jd carbs. your tractor is running lean if choke helps it run better. hope this will help you
Drill bit sets are found on eBay, and also on Blujay. To search, type in "carburetor drill bit set" and hopefully they will come up. If not, write me. (PatB)
That little secret passage as Roberts call it can ----ACT--like there is steel inside of it. It may only be rust, and feels like steel when running a small drill bit in to it. It has fooled many folks.
When you get done, you shoud hear the impulse thumping away at the slowest idle speed if everything else is in good shape.
