JD A Pedestal Question
ChevellRCR
I have a 1945 A with the standard front axle and was thinking about converting it to a rollomatic. There is a junk B right up the road with a rollomatic front end on it but it's a 1950. I'm at work so I can't measure it right now and I doubt it will but will a B pedestal swap over to an A? If not will I have a problem fitting a later model A on my 45? Thank you in advance for your help.
(quoted from post at 14:09:17 02/26/13) I'm pretty sure any styled "A" pedestal will bolt
up but a "B" will not interchange with an "A".
I knew in my mind that is wouldn't but I still wanted to be sure. Thank you for taking the time to answer.
