JD A spark plug type
If its old style 7/8 plug, I recommend the hotter deep reach side wire electrode Autolite 3077. For the later models with the 18 mm plugs the non resistor Autolite 3116 especialy for a Magneto Ignition.
John T
I still see plenty of them at tractor shows, better stock up it sounds like. I always had less fouling and less carbon/soot build up on them (hotter, deeper reach, side wire electrode) then the conventional style 3076 plug. Of course, if we still used the tractors hours a day under full load and at operating temps like they were designed versus light duty parades, the standard heat range (3076) would do fine grrrrrrrrrrr. I run my carb lean as possible and shutters etc to get the temp up to 180+ which reduces premature plug fouling and carbon build up.
John T
Yep, those are good plugs, and the later model tractors especially with two barrel carbs, better ignitions, and the later 18 mm plugs dont foul near as bad, however since he has an Unstyled, Im guessing he may have the older 7/8 plugs in which case those don't fit absent special adapters, so hes stuck with 3076 or my preferred 3077........
John T
