JD AR Parts
pinski
Just wondering if there is anyone on here that has a John Deere AR parts tractor. Mine is a 1952. I am looking for a good upper cast coolant pipe, coolant drain plug and gear shift lever knob. Could also use a couple battery trays and 8" brackets crews, but i doubt anyone would have any less rusted than mine.
I'm in Alberta, Canada and would even consider buying a complete parts tractor if someone has one.
Shannon
i make my own upper coolant pipes. the drain plug is just a 1 inch pipe plug . the pipe is brazed in. i just grind it out and j.b. weld the new pipe in. you need to get the pipe expanded at a muffler shop. bring your calipers with you. plus there is a slight bend to make. i did not remove the cast housing on this tractor as did not want to break bolts. did this on my 2 AR's.
Antique Tractor for Sale..AUCTION
Camrose, AB
1952 John Deere Antique Styled AR 2WD Tractor (Inoperable) 23FI11001-027
This item is Unreserved and sells to the highest bidder.
5.3L 2 cylinder gas engine, belt tested 38 HP, 6 speed transmission, 1 hydraulic outlet, 6.00-16 front, 14.9-26 rear tires
Ser #:
281784
Sales Rep:
Curtis Rusnak 780-888-7722
Contact:
Marvin (Cell) 780-781-4753
Contact:
Marvin (House) 780-373-2654
Office:
Team Auctions Drayton Valley, AB 780-542-4337
Near Camrose, AB
Pto shaft is removed from tractor and on the floor boards. Inoperable magneto is missing.
Call Marvin for more info and viewing appointment. Telehandler will be available for load out from July 4th to 8th from 9.00 to 6.00 PM.
I'm in Beaumont. That tractor at auction appears to be in too good of condition to be a parts tractor? Thanks
geez i better check that out,...i have 4 AR's here . for what u asked for you dont need a whole tractor.
I wonder if there should have been a hyphen after the word "inoperable". In other words, "the tractor is inoperable because the magneto is missing."
Just a thought.
