Mark Klemmer
Can anyone tell me which one on the carburetor is the load adjustment and which one is the idle adjustment. Unable to see colors. Both look the same.
Standing on the flywheel side of the tractor facing the carb, the needle closest thttps://robertscarbrepair.com/adjusting-the-carburetor/1 to 1 1/2 turns outo you is the idle adjust and the one to the rear is the load adjust.
Here is a link to a Robert's Carburetor tech page showing the original Deere instructions on how to adjust the carb. https://robertscarbrepair.com/adjusting-the-carburetor/
Roughly the idle should be 1 to 1.5 turns out and the load at 1 turn or so, depending on if you are pulling with it or just putt puttering around.
