JD baler help
K Effective
I nee some direction, please. I bought a 1991 JD 328 baler last Fall that had been sitting unused in a local barn for most of it's life. Per the owners, less than 1000 total bales. And it looks legit.
It won't run more than four bales in a row without a string problem. The knots don't seem to release and there end up two or three strings held by the knotter- both sides act up independently, rarely at the same time.
It did this to me last Fall when I baled the last 55 fourth cutting bales, and over the Winter I polished the knotter parts as best I could with wire brushes and emery cloth, thinking there may be rust issues. I also added only one pump of new grease to each zerk, and soaked all the knotter moving parts with penetrating oil to lossen the old, sticky grease.
Fortunately, I kept my old 336 and finished the field without missing a single bale!
The new one sure is quiet, and wider, and smooth, but if it won't tie, it's just lawn art...
TIA
Sounds as though you need to bend the sweep arm, best if it lightly touches/scrapes the bottom of the bill hook as it cycles.
Time to get out the manual and open to the "common problems" sections..... :-)
A dull/rusty twine knife can cause this as well too much drag on the twine coming from the box.
I'm no expert, by any means, running a 24T. I had problems with it not tying randomly, breaking shear pins, etc. First thing I did was to time it. Found that the drive chains had stretched. Replaced the drive chains, timed it, adjusted the tucker fingers, new twine and tension adjustment. In short, went over the whole baler, front to back, top to bottom. Currently on a string of over 1800+ bales without a miss-tie. I'd recommend doing all the adjustments, by the book. When I took the tarp off it last week to bale the first cutting, it took two hand cycles to get a good tie off both knotters. I stretch bungee cords to the twine and trip the knotters while turning it over by hand. Then to the field I went. Just what works for me. Hope this helps.
Might have to adjust the wiper arm that knocks the
knott off the billhook.?? Move it closer to the
billhook. Also get a service manual, i got one on
ebay.
