JD combine urgent help needed
Can anyone tell me the length of the belt on a 6600 on the right hand side behind the main big pulley behind the tire up to the pulley that that drives the rpm meter. So from the little pulley behind the the big one up to the one that is attached to the one that drives the rpm. Girlfriends grandpa wants to cut beans before it rains mon and JD is closed tomorrow. thanks Alex
The tach drive belt is a simply big "O" ring.
Part Number: H83077
Part Price: $6.56 USD
Description: RING-O
Specification
Weight 0.07 LBS 0.03 Kg
Inside Diameter 7.475 IN
Nominal Section 0.210 IN
Standard Number Code A
Standard Number Size 367
Durometer 83
that tach drive belt dont stop you from running beans get in the cab put it in gear and run them beans
ive run many acres with out that little oring
or go to ur dealers lot and barrow one off a used combine that sits there ang get one when tey open monday
I need the belt that goes from the little pulley on the back side of the biggest pulley to the pulley that drives the smaller pulley that drives the tach. I have never combined before (Im 20 and starting to farm) and he is gonna have me follow him in his newer combine with this one. Thanks Alex
You got me confused.Are you talking about the one that drives the tailings auger?About how long is it?
Not the tach o-ring one but the belt that drives the pulley that the tach o-ring one is driven by off the big pulley. (It may drive something else on the shaft its attached to) Sorry as I've been around tractors but not combines and this is my first rodeo. Thanks So much. Alex
I'll look at ours in the morning.I like the "first rodeo" thing.Good stuff!
I've been in quite a few rodeos & still get bucked off! ~brad
I would really appreciate it. I hope the fields are dry enough and I can get in some combining time. I work with excavation equipment at work but I am a farm guy at heart. Thanks Alex
Alex,hope I'm not too late.Kind of a hectic day today.The belt I measured on our 6600 is 76" on the outside of the belt and 1/2" wide.
Good luck pal. ~brad
Thanks. Field was too wet :( to get in today. Hopefully get in their soon! This is for my fiancees grandpa but another farmer is wanted me to till and drill wheat and then chop some corn with him. Pretty exciting getting to do all these new things.
