JD Corn Heads - 235, 234, 210???
worknhard
Need some info, what are the differences between a JD 235, 234, and 210 corn heads. I assume the 210 is the oldest and the 235 would be the newest and all are on wide rows. I am sure the newer models would work better, but probabaly not as good as a JD 244 newer type head. Any help is appreciated.
You have your chronological order correct on these heads, the 210 is the oldest and the 235 the newest. I'm sure there are quite a few mechanical differences between the 210 and the 234 but the only differences between the 234 and 235 (that I know of) is that the 235 has expanded metal on the back of the tall corn deflector so that the operator could see into the header more easily, and the gathering chains on the 235 have spring-loaded idlers to keep the chains tight. All of these headers are for wide rows. If you have a choice, go with the 235.
Jd-tom, the 35 series heads also have longer and thinner snouts to get under down corn easier. Just wanted to add to your good information. Mike
The 210 had 2 augers feeding the corn into the cylinder, the 234 and 235 had a sort of beater system. Would seem that that would feed the corn more evenly.
The disadvantage to the augers was that they fed the corn into just two spots on the cylinder, not evenly across the whole width. I know guys would gain a mile per hour or so if they went to a 40 series corn head with an intermediate feeder house.
That's about all I know, hope it helps. Brad
Thanks for the info guys. I currently have a JD 45 combine with a 210 header on it. Do you think there would be any problem hooking up a 235 header to it?? My JD 45 is supposed to be a 1968 model.
