JD D Radiator Removal
Stumbler
Can someone give me the proper steps for removing the radiator on a JD "D" styled?
I would certainly appreciate it.
Marshall
You need a hoist,loader,chainfall. Secure a strap or chain around the top tank both infront and behind the radiator. Three nuts on upper water pipe, 2 bolts on each side on the lower tank. Lift the whole assembly as you tip the bottom out away from the tractor. The whole things is very heavy.
