JD H assembly
Otis
I bought a 1943 John Deere H which is completely disassembled---I have the transmission done and wonder if there is an order to installing the cam, crank, oil pump, and cam follower assembly. Do they have to be installed in any special order?
I appreciate any help.
Otis
Oits,I don't have an answer to your question. However,I recommend you order a book. Do it right,according to the book and you get a long happy life from your tractor. Do it wrong without a book,you may mess something up and may have to redo,spend money to fix the F#@%&p.Spend 30 bucks. Cheap compared to a costly mistake.
(quoted from post at 13:15:00 11/25/19) Thanks for your reply---what book are you recommending?
Otis
1-800-522-7448 for the operator and the service manual. Free parts book is on the JD web site .
How are you setting clearances and torque without a service manual ?
Thanks for your reply. I have both the parts and IT service manuals plus the book on the H restoration. I always set clearances and torque values per spec. The IT manual usually just says "to reassemble, just reverse the
disassembly procedure". I am trying to" infer" the order of assembly of the cam, cam follower, crank, and oil pump from the individual disassembly/assembly procedures but none of the publications address this order directly-
----only the individual procedures. I have never done this before and will probably have to wing it
Thanks again for your help. Otis
There was not a factory service manual for a JD model H. So the I & T is it !
Been years since I did one ,but here goes. I would inspect the oil filter can in the bottom of the main case. Make sure it has not been crushed from the filter cap being over tightened. I'm thinking the cam then the followers then the oil pump and lines and then the crankshaft. Some of those oil lines hook up to the main bearing housings too. Room is tight in there and some small stubby wrenches really help getting the lines tight. Makes sure to use a wrench to hold the fitting from turning and twisting the line too. I think the cam and followers can come out with the oil pump in place too ? But for sure the crank is last in and first out.
Thanks Mike I will try this and hope it works!!! I thought it would be a lot easier to hook up the oil lines if the crank was out.
On those oil pumps on the side of it there is a pressure adjustment screw. IIRC that screw had to come out to get the pump to drop thru the hole in the main case. Hopefully they stuck it back in and you have it.
I can't say about crank in last but it's really tight in there. You'll nick up your hands pretty good. One thing to remember it the upper connecting rod bolts go in the rod reversed, nut toward the piston. It's to clear the camshaft. And watch your timing marks on the crank/cam/governor gears. I&T manual will keep you on the straight and narrow.
Hi Mike (NEOhio). I am not sure what you mean by "Can't do that on the left main". Thanks. Otis
I would advise replacing the oil filter can. The H I have had a donor case installed and the oil filter can had rust holes from sitting outside. That allowed the oil pressure to drop. It is tight inside the case working, but it can be done.
