JD H implements?
Dbltag
I'm looking for a first tractor and like the size of the "H" but would like something useful, not just pretty!!! I know what works with a "B" but what are the implement options for an "H" (with and without a PTO)? Are there any mowers that will work with an "H"?
I pull a 5 ft gyromower with my H and I have a 2 row mounted cultivator and a 1 bottom mounted plow,a friend had a #5 sickle bar mower on his but in tough mowing it wanted to drag the front end to the right, it was a 7 ft. cut, they aren't big enough to handle much, but they are cute..
As far as I am concerned - the very best mower combo for the H is one like Landpride finish mower that has a four-wheel ride. (Forget a belly mower for the H). Then fashion fixturing to the drawbar for the two lower links as with a tree-point draw, and use a cultivator lift down to the two horiz draws to provide front-end lift of the mower. While not that good, I have a pic or two of this set up. I really liked using it! (PatB)
