JD H Manure spreader
JD Brian
I have a JD H, Model 37 manure spreader. What type of chain does it take to run it and can I still get it somewhere? Thanks guys!
Which chain are you looking for? Most likely there are links for the web, the drive for the web, the drives for the beater bars and maybe a drive for the big wide spread bar. Best would be to go to a JD dealer or get a manual which can get you the link sizes you need. Most likely the drive chains will be a 50 or 60 series link and the the web will be an ASR or ASL series. All should be available from places like TSC or other such farm supply store or local implement dealer.
The Operator"s Manual also has complete parts lists in the back. Let me know which chains you are referring to and I"ll email you the JD P/Ns tonight. Apron chain is pretty much standard and I have seen in aftermarket catalogs like Temco, TISCO, etc. My H takes the same chain as my NI 12A as far as width, but the H chain is shorter with fewer cross members.
(quoted from post at 16:16:48 11/17/08) The Operator"s Manual also has complete parts lists in the back. Let me know which chains you are referring to and I"ll email you the JD P/Ns tonight. Apron chain is pretty much standard and I have seen in aftermarket catalogs like Temco, TISCO, etc. My H takes the same chain as my NI 12A as far as width, but the H chain is shorter with fewer cross members.
:o Did you get your hay home from Amherst yet? :?:
Dave 8)
The chain I need is the one on the left side that drives runs the apron and that spreader auger on the rear of the spreader. I think it may be a 55 chain. At least it looks close but I can't find a part number. Thanks guys!
