sgtbull
I recently acquired a basket case JD L, serial # 630753. Its literally a basket case. The previous owner completely tore down the engine and both finals, but the tranny is intact. The sheet metal is actually in pretty nice shape, having the grill, entire hood and fuel tank, fenders, chin and propeller cover with only some slight surface rust. Unfortunately, the radiator was stolen, probably for the scrap value and I don't think it has the correct carb.
The rear wheels are cobbled but the fronts are good. Unfortunately, the manifold is broken and missing the broken parts.
My question is, does this tractor warrant restoration? Mechanically, I think its sound, but its going to need a LOT of stuff to finish it out. I've restored many Waterloo two cylinders, but no Dubuques, and know nothing about parts procurement for them. Are they hard to find parts for? More expensive than horizontals? More valuable AFTER they're done? I'm debating whether to restore it, or part it out so others can get parts they need and make a little cash on it. Opinions please!
Engines and engine parts should be relatively easy to find, I believe there are a lot of L/LA power units out there which is the same engine, my dad had 2, still have 1 if you are close to MN, runs great.
Wheels I would think may be a problem. They look like the same fronts as early M"s on the LA, the L looks like only that.
https://www.proxibid.com/asp/Catalog.asp?aid=67894
In case the link doesn"t work the L went for $6250, LA went for $6500, all tractors were really nice based on the pictures I saw and happened to drive past that day.
I hate to see any old tractor parted, but I would guess parts especially sheet metal would be worth a fair amount.
You have my opinion.
By the serial number that is a 1940 which I believe has the JD made engine. They way you can tell is if the bell housing and engine block are one cast piece or not. If it is one cast piece then it is a JD made engine. In the case any Non-Hercules engine parts will fit. However, you can not necessarily just swap in and out L & LA parts if you want things to be correct and work right. The L & LA did have differences. Manifolds can be bought repro along with a lot of other parts. A carb will cost you $300-$400 and I believe should be a Marvel Schebler TSX13. Rear rims can be found but will be the most costly part. Try the Ridenour's for new/used and Rusty Acres Ranch for used. It does have a tag, which makes it worth more. Most L's & LA's have long lost their tag. If you are going to keep it and show it then I would say restore it. If you are going to restore it and sell it to make a buck I would say part it out.
id have to agree it hurts to see a trator parted out but I have recently sold of my collection of 6 john deere l,la and LI. I sold them to different states all over the united states. I did a complete restoration on each tractor. I didn't break even on any of them. I enjoyed them very very much and don't regret restoring them at all! BUT if your trying to make money off them after a restoration its not going to happen. I also had a garage of L parts and made good money off the parts. Matter of fact I still have some. But if you are going to sell and you have a good ORIGINAL serial number tag your in luck serial tags fell off the l series tractors very easily back in the day and originals are hard to come by.
I have a 46 la with cultivators that i restored last year. They are pretty neat little tractors and fairly simple to restore/rebuild with the exception of cleaning and prepping that weird little frame. Most parts are very easy to come by. The two dealers mentioned above are valuable resources. Radiators are hard to come by in good condition. Carbs are plentiful. If you have really good sheet metal that is a big plus for restoration but its also an avenue to make some good money by parting out. Front wheels were used on l/la/m. Rears can be a little harder to find. There are a fair number of these as parts units out there. Correct well restored units can fetch 4-5k. Having the serial number plate adds nearly 1k to the value when restored.
Ps: I'd like to ask you a few questions about the 14 light hay press you restored a while back as I am restoring one currently. Drop me a line if you would and ill be happy to share any more info regarding the l if you have any more questions.
If you have a good serial Tag That is HUGE on L So I would at the least put it back together and maybe leave it ORIGINAL if all the sheet metal is not painted or restore! Parts are out their I have lots of L parts and if the final drives are all apart I would just get a new set of final drives people scap them ! Here is a pic of a LA original Chris my email is open if you need parts
(quoted from post at 05:40:59 08/13/13) I'd be happy to drop you a line, but I don't have your email.... email me and I'll get in contact.
I can't find your email or either I just can't figure it out but you can email me at rbookermd at gmail dot com. Thanks.
