JD LA steering box seal?
Alex S
Hello,
I was hoping to get some info on my model LA steering box. Is there a seal or cap that goes into the bottom of the gear box? See photo, I can see right into the bottom bearing. Has anyone replaced this cap?
Go to jdparts.com and download PC151 (.pdf format).
The steering gear parts breakdown is on pages 46 and 47.
Mine had the cap that goes in the end there in place without any leaks. The cap on mine looked to possibly be a pressed fit/something that shouldn't come apart? It wasn't something that I was willing to take apart to find out. Looked as though it might be installed from the inside of the box out. Maybe someone else can fill you in on this part.
Thanks everybody, it is hard to make out what part is the plug seal from the diagram or part descriptions. I need to find somebody local to check out another LA in original condition.
So I went and checked my parts manual and what I came up with was that the early LA's used part # L955T Plug Expansion Cap, and the later models used L4590T Plug Cap. I think it is #24 if you are looking at the parts diagram in the parts book. From what I remeber when I had my steering box all apart, it looked like it was put into the assembly from the inside and that there was not a seal or gasket there, just like a pressed fit. I can try and get a picture of mine tonight when I get home if that will help. As far as I know, it's original.
