Geo-TH,In
Haven't mowed in a month
Yesterday I was going to use the 48 inch JD to mow around flower beds and do trim work while the BOSS mows with the Farmall C.
JD starts up, backs up then wouldn't move forward or backwards.
I did trim work with a back up mower. 42 inch Craftsman.
I noticed the drive belt isn't moving.
Grrrr.
I have to remove the mower deck to see what happened.
This means I have to have a plan to get up off the floor.
This summer it seems everything needs repaired. Dishwasher, Central AC, terramite, power vent motor now lawnmower.
Hope this is the end of things needed fixed.
What do you think happened to my JD?
The bolt holding the pulley came lose.
Easy fix.
check to make sure the rod in the back is still engaging the drive. It is the quickest and easiest solution.
