JD M Carburetor
glennybuck,
I believe you will have to find a used one - I'm not aware of anyone making the bowl. It can be tricky, because the identification information TSX245 is on the top half, and there are a lot of bottom bowls that look the same but are different internally. The bowl for the TSX245 (M series), TSX475 (M series all-fuel, very hard to find), and the TSX530 (Model 40) are all interchangeable, but they are different for all other carbs. Bowls for the TSX carbs used on the 420-30 series are different.
Someone will likely point out that lots of carbs use that bowl size, and any of them will bolt up. While that is true, the internal passages (idle, economizer, and to some extent the load) are different.
What happened to the bowl on your present carb?
I've got an M carb without float, will have to look and see what the number is, will get back to you later, if you're interested.
