JohnDeereM50
Still having problems with the generator on the 1950 M. It got to where sometimes it would charge but not great. Less than 8 amps wide open on high charge. I have cleaned all connections multiple times. Took apart generator and cleaned it. Brushes look ok and brush holder springs are good.
I took apart cutout relay and cleaned and adjusted to specs in book. Sometimes it still wont close and charge other times it will. Other times it shows discharge while running.
Yesterday I installed a solid state cutout relay. Now it does charge but at wide open throttle on high charge its no higer than before little less than 8 amps. Wide open throttle on
low charge it shows nothin on gauge. The 3rd brush is adjusted all the way with no change. I had the field grounded during the tests with a jumper wire with no change. No matter what the engine has to be wide open to get it to charge at all which isnt goin to work for me. What do yall think is wrong with it? I guess ill send it to be rebuilt soon.
