JD model 350 mower
eck 44
Went modern from No 5 to Model 350 how do you adjust the belt tension and possible line up?
replacing worn belt new one to short. Know there is adjustment . Thought I would ask before I broke somthing
I have a 350 and believe it is at the end in the center of the frame...but would suggest you get the manual to be sure...
The belt on "Nelson" one of our 7ft JD 350 mowers was worn out and needed to be replaced.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/350%20Mower/Nelson/?action=view&current=IMG_1389.jpg" target="_blank">
IMG_1389.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
The adjustment bolt at the end of the drag bar was not moving the drag bar in either direction.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/350%20Mower/Nelson/?action=view&current=IMG_1414.jpg" target="_blank">
IMG_1414.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/350%20Mower/?action=view&current=008-1.jpg" target="_blank">
008-1.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
Disconnected the break-away bar from the yoke.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/350%20Mower/?action=view&current=IMG_0036.jpg" target="_blank">
IMG_0036.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
Pulled the cutter bar backwards away from the frame.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/350%20Mower/?action=view&current=IMG_0035.jpg" target="_blank">
IMG_0035.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
Put on the new belt and pulled the cutter bar forward to reconnect the break-away bar.
New belt was tighter than a banjo string and could not reconnect to the yoke.
Secured the mower frame with a chain on one side of the trailer.
Secured the cutter bar with a come-along to the other side of the trailer.
Eventually was able to reconnect the break-away bar to the yoke.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/350%20Mower/Nelson/?action=view&current=IMG_1412.jpg" target="_blank">
IMG_1412.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
Belt is still tighter than a banjo string, <a href="http://www.youtube.com/watch?v=_CJbfqofbUE">but it works</a>.
The "correct" method as recommended by the Operator's Manual would be to adjust the bolt on the end of the drag bar.
</a>
Notice the two tension bolts at the top of the above photo.
Loosen the nuts on these two bolts.
Put penetrating oil on the drag bar through the groove on top to help loosen the drag bar.
Keep working with the adjustment bolt until the drag bar moves in either direction and moves freely.
Turn the adjustment bolt counter-clockwise (left) to "shorten" the length of the drag bar.
At some point the belt should fit over both pulleys.
Turn the bolt clockwise (right) to take up any "slack" in the new belt.
You'll like the <a href="http://www.youtube.com/watch?v=WVj1bV3NCEM">JD 350 sickle mower</a>.
Hope this helps.
James Thanks that is the way I thought it would work .Any time I get Pictures it really helps .
Eck 44
