JD model 46A loader
Mike M
Any reason a model 46A loader won't fit onto a JD model 2510 tractor ?
Didn't know if it would be too long of brackets since it looks like it was for a 4020 ?
I foolishly put a 46A on a 2010, and had to weld a new cross bar behind the original in the front. At the time I couldn't find a 36A loader. It was designed for 3010's and 4010's and 20's. It also doesn't sit perfectly center. However ,it works for me with the small 5 foot bucket and limited hydraulic power the 2010 provides. Here's a pic with wider tires I put on the front end hauling a dead tree that fell over.
[/img]
Thanks for the confirmation.
I know someone with a 2510 wanting a loader and there is a 46A came up for sale not too far away.
I told them to go for it since it does have hyd. dump and it looks like all the brackets are there too.
As long as no one has modified the brackets should be simple to mount. if the loader stands are included that helps a bunch. Good luck on the project. Search the forum on this site if you need help with the plumbing. Good stuff on here-very helpful.
