JD Model A headbolt-studs
are0834
I'm having a hard time locating a couple of new/used headbolts (studs) for my Model A JD, any suggestions? These are the 5/8"x7.5" units.
are0834 You must be looking for the A3369R. Brother has a machine shop and makes some of them. You could go and find a machinist and make them. Found these at MSC Direct for an A I did a coupla years ago. Medium steel 125000 tensile strength which is grade 5. Cost is $5. Cut off the 8 inch a little bit and torqued to 150 ft lb. They fit in the block a little looser than Deere studs so use plenty of sealant. Lynn
