JD R and WD-9
GreenEnvy
Drove this at the local tractor show last week. Both tractors were running but only the R was in gear. The guy who created this contraption used a cable master/slave cylinder to run the clutch on the WD-9 and the club member told me it can be finicky at times. Plus if you are not used to driving it, in a panic you can forget to that there is 2 clutches to disengage. So when they run it on the show grounds where there is lots of things to run into they leave the 9 out of gear so whoever is driving it can stop in a hurry. This is the first time I run a tandem tractor like this. If you aren't paying attention you can get into trouble with it fast. I was hesitant to drive it out of the lineup because I didn't know how it was going to handle. Here is a link to a video I took. https://www.youtube.com/watch?v=9bpYm4G7DGI
This post was edited by GreenEnvy on 09/24/2022 at 07:38 pm.
That is the steering pump. Rs didn't have factory powersteering. So the creator mounted a pump on the flywheel and a motor on the steering shaft underneath the hood. This thing steers as smooth as a factory 4 wheel drive tractor. The gear speeds are what I found in the Nebraska test website
WD-9
1st - 2 3/8
2nd - 3 1/4
3rd - 4 5/8
4th - 5 5/8
5th - 16 1/4
R
1st - 2 1/8
2nd - 3 1/3
3rd - 4 1/4
4th - 5 1/3
5th - 11 1/2
This post was edited by GreenEnvy on 09/25/2022 at 08:31 am.
You have to put yourself in their shoes back then. I agree it would have been better with 2 of the same tractors but this is what the guy had to work with. Most of these setups were made in 60s after 4 wheel drive tractors were on the market. I'm sure if he had the money he would have bought a 20k Wagner or Steiger or a 10K JD 5010 or a 15K IH 4100. I know for a fact, Rs and probably WD-9s were only worth a couple thousand by the 60s. So if you had some engineering skills, why not put two together and pull the same plow as the neighbors brand new $12,000 5020 with the benefit of 4 wheel drive. At this same show is a non running Case 500 tandem. My uncle ran a tandem WD-9s. He would start the first one and then pull start the 2nd one because the starting system didn't work . He used it for awhile before buying a used 1256. Pulled the same plow with it.
I always marvel at the creativity of some of these. They were certainly from a time when new iron was expensive, time was cheap, off-farm employment likely far from home, and a mindset of not borrowing money, or minimizing what was borrowed. Today's thinking would be what's the payment on a new one?
The first tandem I ever saw was at the Iowa State Fair in 1964. It was 2 M Farmalls put together and I was in total awe at the engineering it took to accomplish that.
I too like to look what others have made to help themselves. Interesting at tractor shows, I spend more time on old tractors that had things added.
Reminds me of in the 60's a fellow from Iowa that hauled grain into the docks at Chicago, and steel back. Had a International road tractor with another engine mounted out front that he would kick in when going up hills. The manifolds would be red hot at night going up hills.
In our area, I'm told the big farmers mounted a V-4 Wisconsin
engine on the front of JD 720 & 730s belted to the tractor pulley.
They would start the engine for a little more power to get through
the tough spots. I never saw one, but farmer engineering like your
pics to the rescue!
