JD Skidsteer wont start
TGIN
Have a 260 JD skidsteer that when I turn the key on there s no dash lights and wont start . If I turn the key back to acc. there is a faint humming that could be the elec. fuel pump not sure but if I turn on light or wiper switch the humming gets louder but wiper or light dont come on . There s plenty of juice in the battery and the ground is good . Ya cant get to anything on these things for testing just wandering if anyone has had this happen .
If you haven"t already, check the fuse panel next to the seat (left side if looking into the cab). There is a single screw to remove the cover.
Wheck the wiring, connections AND switches for the pressure switches in the seat. There should be two of them unless they made changes from the NewHolland machines...
Seat belt buckle is the next one to check along with the fuses.
Rod
Sorry I did nt say before but I checked all safty switches and the fuses . I did smack the bucket with a tobbacco stick Allan, I thought it would get a rise out of it but no go !
I had similar problem w/a New Holland,I checked the fuses with a test light,anway the test light would work on both sides,but a fuse was corroded and wouldn't let the correct amps thru.
