JD standard serial number
jd4620fwa
Can the serial number on 5010/5020 wheatland verify that it is in fact a wheatland model and also is it correct that the 5010 standard was optional with pto. Was the 5020 available with no pto option.
how do I go about verifying a standard/wheatland model?
thank you
Also can the serial number show proof of no pto/no three point - or just the standard model. Also what was the difference on 5020 industrials - yellow 5020s not the other numbered industrial 700a etc.
The prefix code should be able to verify the the standard versus row-crop. T32 versus T31, if I remember correctly.
You're out of luck on the 3-point and PTO options, unless the Two-Cylinder Club can research that.
