jd straight 310 backhoe fuel issues
georgeR
I had a bit of a scare with my old machine last fall the rad sprung a leak and by the time I noticed it, it had started running rough, for the most part I thought I cooked it, so I parked it for the winter and this spring it started right up but it has issues, I have full power as soon as it starts but it dies out till it eventually stalls, I noticed air bubbles in my fuel filter, cant be good I reckoned, and the new lift pump I put on last year appears to be the culprit, at least something is not right with it and its leaking, but while I am at it there are a few things I have been ignoring.
I have a fuel leak by one of the injectors, I never took one off, not sure if they pop out or thread in, no clue what so ever, I am assuming there are some o rings there, does anybody know better, is there a rebuild kit avail
came across this a moment ago http://www.external_link.com/Fuel-Injector-p/113965.htm, if these are the injectors they are surprisingly affordable I may just as well replace them.
