JD unstyled B flywheel removal
1950jdmi
I have a 38 Unstyled b that started slinging oil out from behind
the flywheel. As far as I know its the original cork seal in there
and I am going to replace it. How do I take the flywheel off?
Looks like I can make a puller, loosen the two bolts behind the
flywheel and slide it off. Some guys have told me there is an
indexing screw on the crank thats only on the unstyled bs. But I
cant find it. Any tips would be greatly appreciated. Thank you in
advance
(quoted from post at 04:16:53 03/21/22) I have a 38 Unstyled b that started slinging oil out from behind
advance
Whatever you do, assuming it isn't shaking/vibrating now be SURE to find the flywheel-to-crankshaft "match marks" or make some distinct marks of your own to be SURE the flywheel gets assembled to the crankshaft EXACTLY as it is now.
