JD wrenches for?
steel
Although I know the wrench second from the bottom will fit my B, we're not sure exactly what the other three fit. Can anyone shed some light please? Thanx
The one you say for the B (before pressed frame) will also fit an H. The clear bottom one fits an A before the pressed frame. I think it fits a G too. I think the top one is used with the bottom one.
The second from the top is a flywheel wrench for an unstyled A. The flat end is for turning the engine by engaging the slot in the fywheel.
That bottom wrench with the off-set will also wit the model D also. There are two styles; one has a longer off-set and I have been told it is the best to use on a G because of the size of the flywheel. That second one down is identical to one we carried on an unstyled D but may be correct for others also. Used in conjunction with the off-set socket ended wrench.
