JD1530 CLUCH
TOM MCcARTHY
I HAVE A 1530 WITH A TWO STAGE CLUCH AND ABOUT 3000HRS. THE POILET BEARING IS BAD AND THE TRACTOR IS SPLIT. IS THERE A EASY WAY TO TELL HOW MUCH LIFE IS LEFT IN THE PTO CLUCH? I WOULD HATE TO PUT IT BACK TOGATHER AND DO THIS AGAIN IN 6 MO. THANKS
Hi Tom- With that many hours and age it's probably best to do everything while you are in there. I just dropped the front axle on my 1530 to replace needle bearings in the bellcrank. I noticed that the pivot pins were worn as well as all the bushings, so you can guess what I've been doing every hour of my spare time!! Ha, ha. I love that tractor but what a pain trying to get those pins and bushings out.
You can remove the clutch assy and see the wear on the clutches. I have to agree with Backwoodsfarm, if you have it split go ahead and replace the clutchs, pilot bearing and throwout bearing.
YES I WAS THINKING THE SAME INTO I GOT THE PRICE TO JIG THE PTO CLUCH AND REPLACE THE PAD, 300.00 FOR OEM PARTS AND 200.OO TO PUT IT IN THEN I STILL NEED TO GET IT BACK IN THE TRACTOR AND CHANGE THE TRANIE CLUCH
