jd173 engine stops when engage mower
You have to be sitting in the seat when you engage the mower. Are you?
If you are, the seat safety switch is not working. Either a wire is broken, not connected or the seat switch needs to be replaced.
I have a JD 160 which had the same problem. I found out the seat safety switch plastic had disintegrated since it was over 30 years old. Replaced the switch and I was back in operation.
