JD2030 tachometer cable connection
Plowery
Lost again. I'm looking for two things; One where is the hydraulic fluid pressure sensor located and where the heck do you connect the tachometer cable. I have looked all over this tractor and can't find either. The tachometer has a 12 to 18 inch cable. Any and all help is appreciated.
Speed-hour meter(tachometer) cable attaches on RH side under battery box to flywheel housing. Hyd sensor if present should be on RH side just in frt of hyd filter OR possibly on shift cover on the top of trans by shifter levers.
On my 2120, the Tach cable attaches to the right rear of the engine block, driven off
the end of a balancer shaft....2030 may be different as noted below. Ben
If your tractor does not have hi/lo the there will not be a transmission oil pressure indicator, at least by what I
see in the parts catalog.
If you look at the right side view of the transmission case in the catalog it shows the transmission filter by pass
valve and switch on tractors with hi/lo and valve/plug assembly for non hi/lo tractors. Not sure if you can swap the
assemblies to allow for a pressure switch.....leaning toward no
