I just had the head reworked for suspected blown head gasket. (Wasn't overheating-just warmer than should be) The tractor ran fine before removing the head. While the head was off, I had the injectors sent off to be cleaned and was told the injectors were 800lbs low on pressure. They sent me re-furb'd injectors-to make a long story short. The tractor is back together but smokes when started, increase the rpm about 1600-1700 rpm the engine is struggling to get there, but smokes really bad. The return line is not stopped up. The injector pump wasn't removed-so it's not the timing. What could it be??
