JD310 aHelp
anlricks
Looking at a JD 310A backhoe with new engine
but it wont move and bucket or loader will not work. owner had new pump installed. still wont move. any suggestions?
i want to buy it if not too bad of a fix
Which pump did they change , the front pump or the transmission pump,,the transmision pump is the one that could be in question . The main drive clutch could be bad , it is a dry clutch in the flywheel that only gets disengaged when the pedal is "fully" depressed, not in normal use.If the center would happen to be knocked out of it the trans pump would not be driven, and cause this senario,
99 times out of 100 some tinkerer takes a wild guess and replaces the front pump without doing any trouble shooting.
Those front pumps don't work when not supplied with oil from the low pressure transmission screen,pump,filter,lines or control/relief valves if they have faults.
If the screens or filters are plugged with fibre or metal powder. Run run away very very fast. Somebody has abused the tractor with the wrong/dirty oil or rode the brakes.Or ignored worn brakes.
