JD40 starting issues
Alberta
Have searched and followed the threads regarding troubleshooting a jd40 that wont start and must be missing something as tractor turns over and smoke out exhaust but wont fire. Good spark w new coil and fresh points and plugs just gapped. Battery 100% and starter cranks great. Plugs wet with fuel when pulled but engine just cranks away and doesnt even sputter.
(quoted from post at 06:44:00 03/13/22) Have searched and followed the threads regarding troubleshooting a jd40 that wont start and must be missing something as tractor turns over and smoke out exhaust but wont fire. Good spark w new coil and fresh points and plugs just gapped. Battery 100% and starter cranks great. Plugs wet with fuel when pulled but engine just cranks away and doesnt even sputter.
Was it running before you changed parts? Or did it quit prior to installing the parts? Did you change the points with the distributor in place? Is the good spark from the coil or from each plug wire? Did you take the plug wires out of the cap? If the spark is at the coil, is the rotor button back in (it has happened) and not broken? Is the contact for the rotor button still in the center of the distributor cap? Have you taken a propane torch to the plugs to dry them out? You might want to try a new set of plugs.
I picked up a handy little tool at my local auto parts store, you put the plug wire on one end and hook the other end to the spark plug to see if you are actually get spark to the plugs, it is also adjustable, ie you can open the gap to see if you are getting a good strong spark. At least on my tractors, A and a 50, seems like most of the time the trouble is that the points need to be cleaned up, even new points which have a coating on them, good luck
Had a 420 like that, problem was
distributer cap. You can clean the
plugs with carb spray and heat the tips
a little with a propane torch
If the plugs are wet, they aren't firing are they? They should only get wet if you crank it over with the switch off I'd think.
Thank you for the suggestions, it wouldnt start after
sitting a while so I put in new points and distributor cap
(cant find the one I replaced) I didnt move the
distributor when I put points in so I dont believe the
timing would be out. Rotor button is back in and I have
great spark from coil and what seems like good spark to
frame proved from each plug. I will try the propane torch
and see what happens, I did give them a quick going over
with my lighter but maybe not enough
Rand
Did you replace the list. cap with the right one? Might be the wires are out of time with the wrong cap.
Thanks for reply..I did something not very smart, I threw the original one away. I will have to check this out somehow, I did make sure that the wires went the same way they were removed but I suppose something could be out of line (although the cap did fit on well on existing distributor but I realize it still might not be right).
(quoted from post at 11:40:47 03/13/22) Did you replace the list. cap with the right one? Might be the wires are out of time with the wrong cap.
MSD is correct there is a Dubuque cap, which you need, and a Waterloo cap (sometimes called a 12 volt cap, but voltage doesn't matter for either one). The terminals are in different locations in relationship to the clips, so timing will not be correct.
I was helping a friend with a M that would not start. We had fuel, good spark and would not get it to start. We found out there
was a bent push rod and an intake valve was not opening due to a broken spring. It appeared water had gotten into the head through
the oil cap and froze at some point. If you pull the valve cover you can verify those valves and push rods are all moving. If #1
cylinder is not opening on intake stroke it seems the engine will not start but it will smoke from #2 cylinder.
(quoted from post at 06:46:30 03/14/22) I was helping a friend with a M that would not start. We had fuel, good spark and would not get it to start. We found out there
Thanks it was the plugs, good to have this valve info in my back pocket.
