JD401-A SCV Leak
IAFJD
Hello, I have a pretty good leak happening on what I believe is the selective control valve, it looks like its coming from one of the caps, how would I tighten that or remove it to check the o-rings?
Thanks for the help.
Heres a pic
This post was edited by IAFJD on 08/12/2021 at 09:07 pm.
As Tx Jim posted you sometimes have to remove things to get to the one you want to work on. It is not a case of checking them, if you disturb one that wasn't leaking, consider replacing it, it may or may not leak after retightening. Also be sure you get the correct O-rings when you have to replace the O-rings on fittings, or you will be doing it again.
What does this valve control? While any valve could be called SCV, to me that term is normally used for a valve controlling remote couplers for hydraulic attachments. A valve controlling a loader is generally called loader control valve, for example.
If you don't have them, you should be acquiring the correct John Deere Operator's Manual and Service/Technical Manual for your machine. I believe the 401-A is the loader model, your tractor will be a 400 or 401, the 401-A loader was used on both. The tractor and loader (as well as backhoe if equipped) each have their own ID tags and manuals for machines the vintage of yours. You need the right tag info, including the serial number in some cases, to get the proper manuals. You can use the on line parts catalogs at: https://partscatalog.deere.com/jdrc/search
The loader tag is on the loader frame. The tractor tag should be on the right side of the transmission in the area above the rear of the right running board and transmission dipstick.
Thanks for the reply,
It is a Loader Control Valve. The tractor is a 401-J with the 401-A Loader and a Backhoe. I do have the John Deere Operator's Manual and Technical Manual for the tractor but there wasn't a whole lot on the loader.
Do I just pry the caps off with a screw driver or is there some special way to get them off?
(quoted from post at 08:43:20 08/13/21)
What caps are you referring to that require prying off? I thought your ""arrow"" was aimed at a cap with an o-ring that screws out of housing.
401-J stands for a 401 tractor with a (J) "diesel engine, collar shift transmission with reverser, with reverser". You need the operator's and technical manuals for the loader, as well as the tractor. The backhoe will have its own tag and there will be manuals for it as well.
(quoted from post at 09:59:49 08/13/21)
I guess my eyesight is worse than I thought because cap the arrow is aimed at appears to be hex to my old tires eyes.
Looks hex to me as well but I can't find a plug there in the parts catalog. It may be the end of the boom check valve or bucket regen valve held in by the body through bolt.
I think you are going to have to remove it from the loader and tear it down to re-seal those. (and I would get the right parts from JD). The Technical Manual for the loader attachment (not the tractor manual) should have info on the valve.
OK that's what I was afraid of, I haven't found just the Loader Tech manual yet, it must be a little more obscure. If I get a bucket to catch the oil would it be ok to keep running it for a while? I need like an hour or so to spread some rock before I tear it apart.
(quoted from post at 12:55:55 08/16/21) OK that's what I was afraid of, I haven't found just the Loader Tech manual yet, it must be a little more obscure. If I get a bucket to catch the oil would it be ok to keep running it for a while? I need like an hour or so to spread some rock before I tear it apart.
Just don't run it out of oil. Make sure the nut I arrowed is tight. Those have O-rings under the washer below the nut. It may be just the way it shows in your first picture but, there appears to be an oil trail from that nut.
You may need to go right to John Deere to find that manual. Here is a link to the JD store for Construction and Forestry manuals:
John Deere Construction and Forestry Manual Store
If you scroll down that page there is a box that says "Help" towards the bottom on the left. Click on it, when that opens there is contact info. I would suggest using the phone number there to call and talk to a person to get the right manual. Have the models and serial numbers from all the ID tags you can find when you call.
Turns out I do have the loader control valve diagram in my manual and it looks like it's the Lift Check Assembly O-Ring. Unfortunately I think I still have to pull it all out to get to the cap screw!
This post was edited by IAFJD on 08/18/2021 at 01:12 pm.
