On my JD4240, when using the PTO if I have the tractor on idle the PTO will kick out (Lever will go into disengage position). Also, I noticed that if at idle and I press the clutch peddle in and then release it the transmission pressure light will blink on and off. It does not do this if the RPM's are just a little higher. I assume that there is a oil leak in the clutch area?????
Last May I had to change the B range gear, while I had the tractor open I replaced the transmission pump lines O-Rings. When complete; I checked all my pressures at the test port as per the Tech manual and everything was right where it belonged.
Yes, there is a new hydraulic filter and oil last may.
The transmission screen was spotless last May too as I replaced the brakes about 5 years ago.
I know I need to check my pressures again, but looking for any ideas on the PTO issues?
TIA
TIA
