I have lost my manual. getting ready to cut beans anyone remember the cylinder setting and speed for beans I seem to remember 1/2 to 5/8 and about 950 cyl speed any help would be great TJ
Terry, you are pretty close on the concave spacing but remember you always want the rear of the concave to be closer than the front. A good rule of thumb is to set the front according to the crop mat coming in and the rear according to the size of the seed. As far as cylinder speed goes 950 would pretty much grind every bean that entered the combine. I have a 45 and can't remember off the top of my head what the combination is but with factory sprockets I believe you can get around 545 rpm or thereabouts. I had some custom sprockets made for mine and run about 625 which works well in hard to thresh roundup ready beans. Hope this helps. Just remember the beater shaft runs around 650 rpm (that is, if your engine speed is correct) and the cylinder sprocket will be as large or larger than the beater sprocket to get the cylinder speed down to where you need to be. Mike
