garyedward
The battery voltage is 12.6 engine off. Tractor running high rpms battery voltage is 13.7. I installed a new voltage reg because occasionally the battery would not crank the engine enough to start it. However the ammeter reads on the + side when I turn the lights on, engine not running and when the engine is running at fast idle the ammeter reads on the - side but still showing 13.7 charging at the battery. I'm confused...If ammeter shows + does that means its discharging and if it shows - does that mean its charging. Obviously I'm not an electrical engineer. Any advice is appreciated
