jf sb 2800 disc mower
mobob
Any idea where I can get repair parts , mostly cutter blades, bolts and belt's for this thing ? Is there possibly another brand that might interchange? I seen somewhere that Kuhn may have made the cutter blade? Think I may have found some but their across the big pond,and I'm in Missouri!
thanks for any help
Bob
I bought my JF disc mower through Adams Tractor in Spokane, Wa. They got it from a distributor in Utah - I can't remember the name of it but you might be able to Google it. Generic after market blades fit my mower, but I found they didn't cut as well and they wore out quickly. I ordered JF branded bladed through Adams and found they are much harder, last longer and move the material faster.
Crown Power and Equipment in Monett MO was at one time a JF dealer. 417-235-5222.
Google shows JF as once being a part of Kongskilde, now a discontinued product line. Kongskilde.com has down loadable manuals and parts lists for the mowers.
Kongskilde is now part of New Holland Agriculture.
Thanks a bunch for the replies guys!!! I'll try Crown power first (a lot closer) then Adams. David Snipes, do you remember what aftermarket blades you bought, incase I have no luck getting original blades? thanks again
Bob
They were unbranded, just a bunch in a box at the Big R tractor store. I brought in a JF blade to compare until I found a size that fit. They were about 1/4 inch shorter than the JF ones - at 3,000 rpm that might make a difference in the cutting ability.
