JI Case 410 need starter
what is with yours? if the armature and fields are good its a pretty simple cheap redo with bushings and brushes. and maybe a solenoid.
You would need to know is it a 2 bolt or 3
bolt starter. Also is it a 410 tractor or
crawler? If it's a crawler you can add a 2
bolt that bolts to the bell housing with
the cut out block. My 310 crawler has the 2
bolt with no starter casting in the engine
block similar to the earlier 300 tractors.
Post over on the Case forum. Don Livingston, John Saili, and J C Maralu all have a wide selection of parts and can answer your question.
