I have searched old posts and tried one of JMOR's wiring diagrams and ammeter still shows a discharge when running.
1948 8n serial # 81104, front mount, negative ground, previously wired for 12 volt, new ammeter, new 12 volt 10 si one wire conversion kit with harness, new paint (ground issue?, new starter and solenoid, buffed starter mount surfaces.
Tested alt by disconnecting positive batt cable when running and keeps running... also checked battery with voltmeter while running and shows 13.9 volts and 12.7 when not running.
Ammeter posts stamped negative & positive. Tested ammeter off of tractor by installing inline between negative and positive leads (neg. batt. lead to neg. ammeter post and pos. ammeter lead motor and then pos. batt. post) with 12 volt motor and ammeter shows a discharge with motor on. Reversal of leads shows a charge.
Kit instructions and JMOR diagram show ammeter wired in positive lead only.
First I wired harness according to kit instructions as shown in first 2 pics then wired according to JMOR Just 8Ns 12v Conversion before SN 263844, and still showing discharge.
Only the coil and starter drawing power and No light wiring yet. Tractor starts quickly and runs smooth on all cylinders, only problem seems to be ammeter showing discharge when it is running and charging. Discharge is initially 30 amps and after a few minutes is down to 10 amps. All suggestions welcome and would like to hear from JMOR. Thanks
