IceChicken
Hello Everyone. I am new to this forum. I signed up hoping that someone here could help point me in the right direction.
I have a John Deere 1020 (Gas) tractor that is having issues turning over.
Once I get it to run it runs great, but If I try to start it, I just get a faint click from the solenoid but the starter motor won't turn the engine over. The Battery is new and fully charged. I have replaced the Ignition switch, and the starter, but it still has the same issue. Almost as if the starter doesn't have enough torque to turn it over.
I loosened the starter and pulled it out about 1/2 of an inch to keep it disengaged from the fly wheel. and it kicks over with authority. Slide it back into position and it can't spin the fly wheel. About one in 30 attempts it will turn over. sometimes more often, but sometimes it won't turn over at all.
I thought about using a torque wrench to turn the engine over to check for excessive drag, but I don't know how much torque would be typically required.
I saw a post on another web sight about a hydraulic lock up that can ocure with this tractor, but there were no specifics.
As a last ditch question, does anyone know about an aftermarket starter that would be gear reduced for higher torque?
I appreciate any help.
