john deere 1020
Anonymous-0
just got a mid 1968 john deere 1020 HU diesel wanted TO KNOW IF THESE ARE good tractors, and how hard is it to find 13.9 36 inch rear tires, and if this tractor has the power to run a 7 ft hay bine, we use a 1956 farmall 350 diesel ta for the hay bine, this 1020 have the hp to replace it in the field
should pull a 9' haybine without any problems as they require only around 35 HP to pull.
Tires shouldn't be a problem, just check with your local tractor tire dealer
Check the transmission screen & filter for trash. Cheapskate owners without reading the service manual tend to dump in the cheapest oil. If the oil isn't wet clutch comparable or is contaminated with water due to age. The wet brakes and clutches will deteriorate.
Check the coolant, not for freeze temp but for corrosion inhibitor. And run an oil test from the crankcase. As will any wet sleeve diesel engine. If the coolant is old and expired due to lack of service. The sleeves will cavitate through and leak.
its a fixers upper but its in good shape has a brand new hydro pump but key way is sheard in the coupler, has high low trany one new rear tire, only issue i can see with it , it must of been a HU Wide rear end LOOKS LIKE THEY CUT THE AXLES DOWN, think it was the 104 inch wide rear AXLE type THAT'S why they cut it DOWN
JUST got it, its going to need worked on some. Has a new hydro pump 6 months old, ford dealer put a new key way in , key way went out week ago , one new rear tire on one side, it has the high low tranny 3700 hours one it, good shape old tractor, must of been a HU with the 104 inch rear axle cause they cut the axles down back to normal size, its a mid 68, got it in the garage now to do the one over and fix the key way for $2200 from a ford dealer aint a bad deal on it, they took it in on trade in
