john deere 110 rearend
blunted
did a taredown end putting it back together. as soon as i tighten up hex screws, one on each side, i cant turn the pully shaft or brake shaft. did this 3 times already. thanks for help.
instead of gasket sealer, im going to get differant thickness of gasket mateirial to make one since it works when the caseings are gaped just a little like a thick puddy knife. thanks for the repliey.
I had a Honda 100 motorcycle that did that when I put the engine/transmission case together with form-a-gasket instead of a paper gasket. Must have been very little shaft endplay designed into it.
